Fuel Economy difference between 304 and 360
Canadian CJ 7
- Media
- 11
- British Columbia
- Current Setup 1985 Jeep CJ-258, 6cyl -T-5 5spd 273 gears.
I am curious if there would be much of a difference with fuel economy between the AMC 304 and AMC 360? I am still on the fence deciding between the two engines to replace my AMC 258 i6 / 4.2l . I be happy with a engine around 225-250 hp for the my jeep and I know the 304 would be up to it. I have a 304 waiting on a engine stand to be rebuild, but I have come across a few 360's. I plan on putting in a T-176 Transmission and 355 gears and will be running 31 inch tires and a Edelbrock 600cfm 4bbl. What do you guys think?
Cheers, Brian
Cheers, Brian
on a 360 instead it has gobs of torque and horsepower with a 2bbl. I beleive you will be quite happy with a 304 and have less broken parts at the end of the day,I also dont see what is wrong with swapping to some 360 heads if you want the better flow.?
