Engine Fuel Flow Stumper!
N9VIW
- MOzarks
- 1982 CJ-7 Laredo, 258, T-176, D300, D30/M20 w/ 2.73s :eek: (wife's)
1982 CJ-8 Laredo, 258, T-18, D300, D30/M20 w/ 2.73s. :barf:
1967 CJ-5, Buick 225, T-150, D20, D30/D41 w/4.27s
Guys, I gotta take a break from beating my head against this Jeep, I got a headache and an AMC logo stamped across my forehead...
1982 CJ7 , swapped-in '93 242 with the Gronk MC2100 carb conversion and HEI, T-176 , Dana 300 , 2.73 in stock axles. 20-gal poly tank.
It was my daily driver for the last 6 years, first with the stock AMC 258 i6 / 4.2l and then with this donor 242. I've been driving on the 242 since April, and not a lick of trouble until a month or so ago when it started acting like it was running out of gas occasionally. Now it seems I get less and less further from the house every time I test-drive it; I'm waiting for the day when I won't even be able to get out the driveway.
So far I've replaced the fuel pickup sock, fuel pickup, all rubber lines to the tank including the breathers, all steel lines to and from the tank. Because the 242 has no mechanical pump provision, I have a Carter vane-style electric pump mounted to the frame near the engine. New pump. New filters, both the inline filter I put before the pump (when I was diagnosing a similar issue that wound up being rusty steel lines) as well as the stock dual-outlet filter at the carb. All rubber lines to the filters, the pump, the carb, and the return line to the steel return to the tank. Rebuilt the carb, new needle and seat, and the float floats and does not sink. New air filter with clean prefilter.
It started one day when I got almost to work and it started giving me guff. After work I made it to the local station and filled up, and no problems for weeks.
Next time I was on my way to work and got maybe halfway there. Pulled off at a station and filled up, no problems to work or home again.
Next DAY I made it to the next town over, and it started again, with a full tank! Coaxed it home, and it died on the way. I pulled over and looked it over, couldn't see anything wrong, but the steel line I had from the pump to the carb (at the time) seemed hot. Vapor lock? Got it started again and got it home and took the wife's Tracker to work.
I replaced the steel line from pump to carb with rubber, and took it to work the next day. I made it maybe 5 miles when it started running out! Raced home, coasting and goosing it all the way, took the Tracker again.
I drained the tank, dropped it, cleaned it, blew the lines out, replaced the pickup sock, replaced the inline filters again, rebuilt the carb, and put it all back together with fresh gas.
Took it to my neighbor's house a mile away for a test run, and it died in his driveway. And again a half mile from there, and repeatedly thereafter, every few hundred feet. On one stop I opened the carb with my Leatherman, and the bowl was indeed low, darn near empty. No leaks.
I was able to make it home by pinching off the return hose to force all fuel to the carb, but several times I almost flooded it out and had to rev it up to clear the carb.
When I got home, with the engine off, I ran the fuel pump and noted that, with the return line pinched, the pump would not overwhelm the float needle- it didn't overflow, it just stopped flowing. When I removed the zip tie I'd used to clamp the return line, it started flowing again.
I want to get back in the saddle again, not only because I LOVE our Jeep and I HATE my wife's Tracker, but so she'll have something to drive in my absence.
I'm at an absolute loss- can anyone help?!
Nick
Nick
