fuel line routing
jeepboy45
Old Time Jeeper
- Altamonte Springs, Florida
- 1979 CJ-7, Newly rebuilt AMC 360!, fully rebuilt GM TH400, Quadra-trac TC w/Milemarker 2x4 conversion, AMC mod 20 rear w/1 piece Moser axleshafts, mod 30 front w/tie rod flip and castor correction shims, 4 in lift, Centech complete wiring harness, dual electric fans on 3 core aluminum radiator, tilt steering wheel, 20 gal poly gas tank, new J20 steering box, MSD 6A ignition combined with TeamRush distributor mods
To all those with AMC V8's : Can you put up pics of how you routed the fuel line up from the pump and eventually to the dual filter and then to the carb.
Especially those of you with either an MSD big cap, or HEI.....and power steering
I have an MSD and there really isnt a lot of room between the distributor cap and power steering pump housing.
Before I start bending fuel line, it would be cool to see how others felt about routing it...
thanks in advance.
brian
thanks in advance.
brian
