Fuel System
Saunders
Hello,
New guy here Having a problem with my fuel system. I started up the jeep this morning and noticed fuel pouring from what I think is the return line from the fuel filter to the tank. I have had the jeep for a few months and have not had this problem before.
The p.o. had the green line coming from the rollover check valve jammed into the return line from which the fuel is pouring from. (This must have become disengaged when i was doing other work at the rear of the vehicle). They also have one of the lines plugged coming from the top of the tank. From what I can tell the charcoal canister has been removed.
Why would so much fuel be sent back to the tank? What can be done to fix it? I have made sure the vapor return line on the filter is facing upward.
Thank you to all in advance for your time and help!
