fuel venting system modification
Oldguyinajeep
- Derby, KS
- '86 CJ-7 258ci 4spd Dana 30 and 44
Howell TBI Fuel inj, Headers, Dual batteries, Warn winch/air compressor, rear
disc brake conversion, Detroit locker (rear), Eaton E-locker (front), 4:10 gears, 2.5 in Rancho lift, 1" body lift, fully armored, 35" BFG KM2s, Warn front hub conversions, line locks front and rear, roll cage, warn front bumper, rock hard rear bumper/tire carrier, DUI ignition, dual electric fans, LED rock lights
Out in the Colorado mountains a few weeks ago, I noticed gas dripping from the left rear of my CJ7. It was coming from two rotten fuel lines coming out of my gas tank, and were attached to a pod, which was attached to another pod, which had another fuel line going somewhere.
I've since learned that this is my fuel vent system, and that the two pods are a rollover valve, and a liquid check valve. I replaced the leaking lines, and this caused a pressure buildup in the gas tank, which produced hissing at the gas cap, and belching of vapor and puking of gasoline when the cap was removed. Obviously, the vent system wasn't working.
So...the adventure began. This is a write -up of my solution. I've searched several forums, and followed many dead ends. First, the valves: Delorean makes a replacement liquid check valve which many have used. It looks like the mounting bolt location is identical. You can also find replacement rollover valves. The solution I chose is a valve which takes the place of both. It's made by MTS, and it's the JLCV-1. They state that it will perform both LCV and rollover functions. It looks like somebody makes these in their basement, but the reviews are good.
The valve comes with a brass tee at the bottom. In this pic, I've added two small lengths of hose and a couple of 90 degree connectors to get the lines going the right direction. It comes with the pictured mount, which just requires drilling one 1/4" hole.
https://www.jeep-cj.com/forums/photo_popup.php?e=vB_Editor_001#
This picture shows the valve in place, as I'm fitting it.
The metal edges of the fender support worried me a little, so I wrapped the fuel line in some clear tubing, and taped it in place, where they might come in contact with the edge. I also bent the metal edge upward on the inboard side. I drilled another small hole in the fender support, and nylon tied the outlet line of the valve, for extra support.
Now for the vapor canister. There are lots of old posts which feature part numbers which would be "near-exact" replacements. That is, they have the same number and sized ports as the OEM canister ( CP-1061,3045, 1022, and 1109). The problem is, they are no longer available. At least anywhere I could find. What I wound up using was based on one solitary post (in this forum, I believe). My apologies to the author for not writing down his name. He used a Standard CP-1039, which only has three ports. The one labeled "tank" goes to, well... the tank. The one labeled "purge" goes to vacuum (pvc line in my case, since I have a Howell TBI set-up). And one is the air intake. It could be connected to the air filter, but also has a splash guard on it, which can be left in place so that this becomes the air intake, which is what I did. The bottom is enclosed, unlike the OEM canister which has its filter there.
I absolutely cannot believe how much better my jeep runs. I wish I had done this long ago, but honestly, this vapor system is just something I ignored. Live and learn.
Another note: Apparently if emissions are not an issue where you live, or in your belief system, those two lines coming out of the gas tank can simply be plugged, and you can go get yourself a vented gas cap and be in business.
