Full droop?
Anyone else's tube and rod this close to leaf's? Seems real close at full droop '79 CJ5 . View attachment 13528View attachment 13529
Sent from my probably outdated electronic device, more than likely tracked by our government.
the profile says 1979 but the axle in the rebuild pictures has drum brakes. Do you have some kind of mix and match going on here?
Is the tie Rod and Drag link after market and larger than stock? The short answer would be to do a tie rod flip..........whereby with the use of a new sleeve you change the direction of the taper in the spindle and drop the tie rod in from the top as opposed from the bottom.
Hmmmm where would I go about learning more about this
