G2 Jeep TJ Axles
G2 Jeep TJ Axles
Im Not Spam
News Posting Bot
In Cyber Space.
The Information Highway.
G2 Jeep TJ Axles
Stronger Jeep Axles from G2
Built-to-Order Dana 44 axle assemblies. G2 complete axle assemblies are built to make upgrading easier, and are ready to bolt directly into a Jeep TJ. They are assembled using the finest components including OEM ring & pinion sets and heavy duty chromoly axles. The front assemblies come with new ball joints and use the existing outer steering knuckles and brakes from the Dana 30 . The rear assemblies are designed to use the existing drum brakes, or can be ordered with the optional disc brake kit for better performance. Built with all new components and tailored to fit your needs. These housings can be ordered with your choice of a locker such as ARB Air Locker, Detroit Locker or a True Trac Limited slip, and come with gear ratios ranging from 4.10 to 5.13.
Source:
G2 Axle & Gear
877.852.7720
www.G2Axle.com
Read More | Digg It | Add to del.icio.us
More...
