Gas doesn´t get into pump...
Black Arrow
- Guadalajara, Mexico
- 1978 Jeep CJ5, stok drivetrain and engine (4.2) only a 3" bodylift, just bought and eager to restore.
2000 Jeep XJ, Completely stock.
Hello every one:
I have a problem with my 78 CJ5 , it simply doesn´t get the gas from the tank into the pump,
First I tought a fuel pump replace should do it, but I wanted to prove that in the first place, so what I did is disconnecting the fuel line from the pump and put a hose from a gallon of fuel to the pump, the jeep started and ran very good, fuel filter was filled normally.
So, I am now completely sure that the pump is in good shape, I even replaced a couple of hoses that were too old to handle pressure and another that was ripped.
That doesn´t leave me with much options to go.
Any of you know how to resolve this?
I noticed two vacuum lines that are attached to the tank, I don´t know if vacuum can also be a problem.
Thanks for your time....
