gas tank/sending unit question
OK, new to the board, new to Jeeps.....but don't hold those things against me!
I just purchased a new tank and sending unit for my 1973 CJ5 . Taking the stock tank out was easy enough. My stock sending unit has only one tube, the one that goes deep into the tank for fuel pickup. The new aftermarket one has two tubes...an extra that only goes about 2-3 inches into the tank. What is that one for? Should I just cap it off and ignore it?
Also, new sending unit has two electrical connections...my stock one had just the one where the eyelet for power is held down with a nut. This one has another slide-type connector on it. What is the slide connector for? Again, do I ignore it and just use the one where the power eyelet goes?
Thanks for your help in advance....hopefully you'll be hearing from me a bunch, as money allows!
