Gaskets
Gaskets
driver007
Canada
1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
I am in the middle of a Transfer Case rebuild. Should a person use the gaskets on the alum adapter plate etc or use a sealent. Is there a pro or con to the use of gaskets?
The only gasket that I would not use on the aluminum housings is the one for the shifter housing, as it would change the preload on the rear bearing. I just used the 518 sealer in the corner of the aluminum housings.
The paper gasket is probably as thick if not thicker than the shims on the rear bearing.
I picked up some loctite. Still have to get some super 300.So in todays world we do not really need gaskets?The big gasket between the tranny and bell housing if used would only get a perimeter bead of sealent? Would there be a reason to use more expect around bolts etc when using a large gasket.
