getting my jeep running, need some help
dizenman
So a couple weeks ago I bought a '76 CJ7 that I knew needed some work. there is something wonky going on in the ignition system, and the brakes needed some work. The brakes are pretty straight forward, but im having trouble with the ignition system. right now, im not getting any spark. I started by replacing the coil, but im not getting any spark from there. my next thought would be the ignition module, but the wiring on this thing is pretty bad. im considering replacing the entire harness. I'm also finding some components I'm having trouble identifying that are concerning me. the one I'm currently having trouble with is located bolted to the passenger side of the engine, below the ignition coil and a bit further back. it has wires going to it from the same loom as the coil. Can anybody help me identify what this thing is? also, would the module be the right next step in figuring out why I'm not getting spark?
Thanks in advance.
Thanks in advance.
