Glooming on my axle perches... shackles not vertical.
mdeluca
Full Time Jeeper
Hung my rear leaf springs (without the axle yet) and the rear shackles hang vertical.
When I set the axle perches down onto the spring pins (I've got to muscle the springs outward) the shackles angle outward. I measure the springs, center to center at the forward pivots and they are 3/4" narrower than the axle perch holes. Divided by two, each perch is 3/8" outboard of the spring pins. Double that at the shackle and I figure about 3/4" per side and it looks terrible.
I'm thinking I've got one of three options:
1. Slot the shackle hanger bolt holes so the hanger can move outward.
2. Take the axle somewhere to have the perches cut off and re-welded at the correct locations.
3. Forget it and leave it alone. Its been that way for 32 years.
What do you think about this and, if it is taking the axle somewhere, who does this kind of work typically.
Thanks... I am very sad...
