Gm gen III Lr4 to sm465, clutch problems
Severett
Texas
77 CJ7, gm gen III LR4.. SM465
Dropping Gm Gen III 4.8l Lr4 vortec into my 1977 CJ7 .. Have it bolted to sm465 Transmission with How hydraulic throw out bearing . When I tighten down the pressure plate I see significant interference with the flywheel, the fingers bend significantly.. Now I can not get clutch to disengage .. I feel that I either need to shim pressure plate or find a " thinner fly where".. Does this make sense. Any help would be appreciated
I had a similar problem putting the 465 in my CJ. The bearing nose cone was about an 1/8" too long. I cut a 1/4 in off and had no more problems. Also, if you have an adjustable throw out bearing, it may need to be taken in a bit. Not sure if a hydraulic bearing would be similar to mine but it's worth checking.
:ww::dbanana: :banana:
To you BOTH.
I have no experience with this issue. Interested to see what's the best way to solve this is.
2 weeks, 1 day, 23 hours, 4 minutes, 13 seconds
  5.0%
