got a tire question for all you knowledgeable peeps
JTNCHRIS
CHARLESTON WV
1980 CJ5 AMC 360 4SPD MAN TRAN, dana 30 front dana 20 rear, edelbrock 1406 carb, accel super coil and wires, american racing stainless rims
ok so I bought a set (5) of refinished rims. the question is what tires go on a 15x8.5 rim w a 5" bolt pattern? and would I use a spacer to get more clearance from my rear springs?
Lets start with this. If its a 5in bolt pattern put up an ad and sell them to a Grand Cherokee owner or someone else that can use them. :) Cjs are 5.5in. If they are the right bolt pattern there are a boatload of tires you can put on that rim. I think your looking for what the widest tire is youd use on that wheel and that would be 12.5 in. in my opinion.
What Pete said.
Anything from a 10.5 to a 12.5 tire would work.
A CJ axle has a 5x5.5 bolt pattern. (5 bolts in a 5.5 inch circle). To use 5x5 bolt pattern wheels you will need an adapter like this:
1.375 WHEEL SPACER ADAPTOR PAIR JK 5 on 5 to 5 on 5.5 INCH 07-09 WRANGLER"
