Grounding on Fiberglass Body
I’m in the process of installing a Painless wiring harness in my 79 CJ5 with a fiberglass body. As for ground, the engine is grounded to the frame, I’ll run extra ground wires to connect the dash, core support, starter solenoid, horn. Anything else I’m missing that I need to ground? Thanks
pm sentmstar, did you use a harness to run that setup or did you do everything yourself?
Well to the parts store and the shop i go,i have work to do. Never gave a buss a thought.Anything that runs off of 12 volts will need a direct path to ground to your battery. The ground wire should be of equal size that is powering the circuit.............In some case's a ground buss is helpful say under the dash so that your only running one large lead from the ground on your battery to the buss. Then smaller leads from accessories to the buss. Do some planning to eliminate extra runs.
Your turn signels & marker lights both front & rear........and headlights.
