Hand Emergency Brake?
jeepn4evr
- CO
- 1974 CJ5 - 258 from an 85 CJ7, hopefully soon to be replaced with a FI 4.0 HO from a 96 Cherokee, T-18 tranny, stock brakes, gears & axles (d30f & D44r), hopefully soon to be replaced with wide tracks & disc brakes. Body restored
Has anyone installed one? What did you use & where did you install it? Pics would be nice.
I have a roll cage in my 74 CJ5 which of course gets in the way of the foot emergency brake lever. It was ok as my lever was frozen in place & I needed to replace it anyway. However I thought a hand brake would be great but just cant figure out how to put it in & the best spot. There really isn't enough room between the drivers seat & the side of the Jeep or between the console I put in. I like the console but if its a choice between having an emergency brake or not I geuss I can put a smaller console in or something.
Also am wondering if I can attach the hand lever to the stock cable (as it still there & moves freely) or should I pull that out & get a different cable.
Due to the seat frames & mounting points being attached to the cage I would assume I need to put the hand brake on the cage somehow also as it would hit the cage & wouldn't work if it was attached to the floor.
