Has anybody done a 4bt swap in their Jeep?
GoldenEagle36
SW Pennsylvania
1977 cj7 Golden Eagle 304,automatic, Quadra-trac, full restoration just "finished." 4 inch superlift, lift shackles in the front, sitting on some KM2 Mud terrians
1999 tj 4 cylinder ax5 trans 3 inches lift 31s
1956 Dj3a all original except axles and engine, Hurricane 4 cyl. 4x4 conversion, 27,500 original miles 58 Jeep-A-Trench cj5 8000 miles.
I've been leaning on this for forever... On my dads Jeep, his 99 tj, the frame is getting really bad (for 224,000 miles, who can complain?) but the old 4 cylinder is losing a lot of power and the Ax-5 doesn't like going into reverse. I know she's getting tired so I have a plan to give her a new lease on life. I want to swap a Cummins in. I have plans to get a new frame, do some reinforcing, drop in the cummins, put an NV4500 behind her and maybe an Atlas tcase. Also with some locked Dana 44s. Put a new 6 inch on and 1inch body and run 36s with custom bumpers. But the real question I have is how is the 4bt under the hood? I've heard there's a lot of vibration due to the torque, and just because it's a diesel. I want to do this really bad, but If there is excessive vibration I want to maybe prevent some of it. And maybe some drivetrain help so I don't just blow money on stuff that the 4bt is just going to rip apart. Thanks guys and I hope you all had wonderful Easters!
Ive got 2 buddies running 4bt's in YJ's. Neither one vibrates horribly. Both of the motors fit under the hood, one has the turbo sticking out for show. One guy is a really good fabricator and did all his own work.. The other paid 10gs for one with the motor installed and has spent another 3-4 grand getting it right.
Keep in mind the frame needs to be beefed up and the axles will need to be replaced.
