Having the CJ5 Rhino Lined.
CJ7JEEP1979
Bowling Green, Ky
1979 CJ7 304 bored .30 over with a performance cam. 4 speed manual, 35x12.50x15 tires, 4 inch suspension lift. 4 barrel Holley.
Good Evening everyone,
My CJ5 and CJ7 have been sorted out mechanically and no more leaks. Yeah I know a CJ not leaking....what's wrong with it! haha I have the front section of the CJ5 flooring down to bare metal and I am having a welder patch up the pinholes all over the flooring and then patch up the sides and then I am having the inside of the tub rhino-lined. I got a fair quote which includes priming the inside of the tub with rust inhibitor primer and having the tub and the roll bar lined. I have cut out the bolts holding the roll bar in and that will just lift out now. I have replacement bolts and nuts ready to go once everything is done. The inside of the tub and the roll bar will cost me 600 at most to have done. Fantastic deal as this is at an actual place that does this on Jeeps and other 4x4's all the time where I live so I don't have to attempt this myself. Should have everything done by sometime in March as Monday coming up I am meeting with the welder so he can give me that estimate and then The rhino lining will be done in March.
If you got an air comp U-Pol raptor is easy to do yourself.
Sent from my E6810 using Tapatalk
3 weeks, 1 day, 18 hours, 7 minutes, 36 seconds
  5.0%
