HD bellcrank build
Clutch belcrank? What vehicle? more info-fill profile info.
85 CJ7 AMC 258 i6 / 4.2l all originalneed direction/site to build bellcrank w/o clipsand plastic bushings pissing me off getting towed home Ican weld just need prts list thx in advance
I have never heard of this problem. There are lots of companies that make replacement clutch linkages but they all reuse this piece:the plastic bushing that the steel sping clips hold keep failing
I have purchased CCVI bearings will fabricate and supply pics was told I might have bad motor mount --noevidence back to fabrication
If you really want to replace the plastic bushings you can fabricate something yourself but I don't know if anyone else has tried this.
You could replace the bushings with flanged bearings like this:
But then you would need a long rod going through the assembly. More trouble than it's worth if you ask me.
