Headlight dedicated ground - huh?
CJ7inNH
- Southern NH
- 1983 CJ7
6 cyl, 4 speed
Dana 44
4 inch skyjacker lift
weber carb
I debated on adding to one of the amazing grounding threads, but thought this would throw it off form the intention.
I did all of the primary groundings that are listed in the big threads - JeepHammer.
Starter, alternator, block, tub, frame - all have dedicated grounds, and I have put in a few bolts with grounds to run more off of.
Question on the headlight ground - I thought the headlight was grounded through the mounting to the grill and that's the weak point and reason for a dedicated ground. When I pulled the headlight last night it still went on while not attached or touching the body. So how is it grounded, does it really need a dedicated ground, and if it does, where is it best to put the ground wire.
I just thought of this while driving into work and don't have the electric schematics to look at.
Thanks.
Thanks.
