Heater cabling
Heater cabling
frhrwa
Pacific (NorthEast) Washington and Las Vegas 1/2 y
1984 CJ-7 (just bought it, so I have to do some work and see what it has in it.. other than 4.2L Auto.. 4" lift, 33" tires... my '75 had a 304 2" Burbank supspension, warn winch, full cage, all the goodies, the '79 had a 401 turbo charged hi-po with t98 or 18, which ever one had the granny low first gear (never can remember which).. had all the items needed to 4wheel, none of the show and go poopie.. I don't believe "chrome will get you home"! I'm also not one to go out to see if I can tear up my jeep, I go where I must, usually with a group that I hung with.. Used to be part owner in Diablo Off Road Center in Concord California.. Jack Essex owned Diablo 4WD, George Clause was Mr. Base CAmp, and mine was "Sounds Etc" all under one big roof "the Diablo Off Road Center"..
I just replaced the core and the fan motor (upgrade), found one cable shot, the one that goes to the defrost lever on the far right passenger side of the heater.. I ordered 3 cables from Morris, each a different length.. but, the longest one will no where come near reaching that farthest lever? I'm about 1 1/2 ' short? is this supposed to be a two piece cable that somehow I missed where the slave cable might go? or did I get the wrong cable? or? thanks.. wayne
I am in the same boat...sort of... I can pull the knob to open the vent on the passengers side, but it won't close, so some kind of link is missing and the PO made a mess of it and I can't figure it out. Seems to be the same cable but something ain't right.
here's a copy of the drawing I found..
I suspect I have a problem with one ore more of the levers...looking at what you posted, these could get rusty. We're you able to figure out your cable? Looks like there is a link between those two that are adjustable. Maybe that is the link where those cables join. :confused:
yes, the cable I got hooks to the top of the heater, where there is a linkage that has a cable that goes to the right side (passenger) of the heater.. it does have an adjustment, but didn't need to mess with it.. shot lithium on all of the linkages and cables.. there is one bar that hooks to that linkage that goes back to the drivers side, haven't figured what makes it open or close, nor what it does? also found an extra part that I have no clue what it is? picture below?..
