HEI Distributor, '69 V6 Dauntless
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
This isn't my vehicle, I'm asking for a friend.
The Jeep:
1969
CJ5
Compression ~165 (Can't exactly remember, it was checked just before the HEI swap and was good then)
Carborator rebuilt at the same time as the HEI swap. By a well known and respected carb. shop here in Tucson
Fuel Pump is a new electric holly
Motor this is a low mileage motor in great shape
1 - The motor will rev. freely when not under a load
2 - The jeep has an over drive Transmission
3 - When accelerating up to highway speeds, something he never had trouble with before, between 55 and 60 the motor will start popping and blowing back through the Carberator. The trouble seems to be when the Jeep is under load.
What has been done:
There was a question about his advance setting. He fooled around with about every combination you can think of. 0 advance, 3, 4, 5, -8 with no change. The vacuum lines have been inspected. The fuel pump was old so it was replaced with the recomended Electric Holly. He took the Jeep to the Carborator rebuilder and they went through it with a fine toothed comb and found nothing wrong with it.
I have suggested:
Running a wire straight from the battery to the distributer. Change the ingition module.
He believes that he should check the voltage while driving the jeep.
The Jeep:
1969
CJ5
What has been done:
I have suggested:
