Help decifering these numbers
Jroch
Tampa
2007 Toyota Tacoma 4x4, 1985 CJ, 2006 E250
I was curiose exactly what I had for running gear so I scraped away as much grime as I could to reveal these numbers but can't find them on the net. it is possible I transposed a couple as it was very difficult to read
Transmission I found these
1307065901
WG7IV
R.
I68
Transfer Case
DANA C18-1524-S(or5?)G
I am guessing on the Transfer Case it's a C18 but looking at the spec sheet sticky for Transmission and transfer it shows 2 sticks on the Transfer Case and I only have one?
The Transmission is a 3 speed reverse all the way left and straight up 1'st straight back from reverse.
I couldn't find any numbers on the front and rear axle?
Second part to this is if you can tell me what I got, what are opinions on them what I can I expect for known issues performance etc:
Justin
I continued to keep looking on the net for the casting numbers, would the 1'st four be the identification, I saw what i thought was 1307065901 possible I miss read the 7 and was a 2 giving the 1'sr four of 1302 which would give me a T-14 tranny mated to a C18 Transfer Case ? I also came across this while searching thought I would post it
1946-1972
1955-1973NAME: T-90
SPEEDS: 3
CASE LENGTH: 8"
CASTING NUMBERS: T-90
BOLT PATTERN:
SPEEDS: 4
LENGTH: 11.875"
CASTING NUMBERS: T-98
BOLT PATTERN:
1966-1968
1968-1975NAME: T-86
SPEEDS: 3
CASE LENGTH: 8"
CASTING NUMBERS: T-86
BOLT PATTERN:
SPEEDS: 3
LENGTH: 8.375"
CASTING NUMBERS: T14A,or 1302
BOLT PATTERN:
1976-1979NAME: T-150
SPEEDS: 3
CASE LENGTH: 9.250"
CASTING NUMBERS: 2603983
BOLT PATTERN:
It looks like it got a little turned around in the copy and past
what year is the jeep?
oh d 18s had single sticks, what engine?
Baja thanks for your reply, the jeep body is a 1985 but nothing I don't believe is OEM, with the exception of maybe the axles? This is what I can tell you from the PO
The Engine is a 343 out of a 1969 AMX
Was told Transmission and Transfer were up graded to a T-14 cast iron, thats all I was told, I have verified the motor although there is still some confusion on the heads but that is being debated in another tread.
Are you thinking that I have a D18 Transfer with a T-14 Transmission ? if so what can you tell me on them any good?
Thanks again for your assistance
ok then, lets get to a few things
If you have a D18 tcase you will need to be running a rear offset diff, it will be offset to the passenger side. If not that is not a d18
the Dana 20 had one shifter also, but used a center pumkin differential in the rear.
do you have any pics?
Pictures are worth a 1000 words.;)
Sorry for the delay guy's been a busy week. Here are some pics from underneath the Jeep. The Rear Axel the pumpkin is in the middle of the axel, the front is off set to the passengers side of the Jeep. Hard to get a good pick of the Transfer Case but included on of the rear of the case Thanks for all your assistance with this
I personally guarantee it's not a d-18!:eek: Look's like a good ol' Dana 300 Transfer Case , Dana 30 front axle with a P.O.S. (whoops did I say that?) AMC model 20 rear. :laugh:
Shift patterns on worn out shift rails of old t cases are pretty much what ever you can get them into! :)
Well now I am really confused :confused::confused::confused: LOL, I pulled the body cover so I could get a good look at the shift linkages, what I have is a single shifter the linkage then conects to two :dung: rails that go into the transfer as I move the shifter one will slide in then slide out and the other slides in heres the best I pics I could get, I oppologize for the full sizze but scaled down you really couldn't see the details?
I have to agree with "Lil'5 & CJ" from the other thread. That linkage does not look like a Dana 300 to me. A pic from the rear might help.
you may have a home made shifter linkage, I think it is time to take that thing down to your local 4x4 shop and get them to identify that puppy. then maybe you can get straitened out. I have never seen a shift patern like that, or a sifter linkage lik that, I think we have PO shenanigans going on.
Well now I am really confused :confused::confused::confused: LOL, I pulled the body cover so I could get a good look at the shift linkages, what I have is a single shifter the linkage then conects to two poopie rails that go into the transfer as I move the shifter one will slide in then slide out and the other slides in heres the best I pics I could get, I oppologize for the full sizze but scaled down you really couldn't see the details?
I think there is some schanagens going on with post I do not recall, calling them "POOPIE RAIL" LMAO, CJ you working on some creative editing there :D
And a shot of my old Dana 20 stuff - see the square bolt head?
Don't know where that came from! :)
