Help! I know i'm forgetting something!
wolfclan
- Charleston SC
- 86 CJ7 258 AMC20(for now) 5spd mostly factory.....but hey, I've only had it for 3 months!
So after tearing down my AMC 258 i6 / 4.2l and finding a cracked piston skirt, low comp on 3 cylinders and 2 burnt valves, I started on a major overhaul. I have just gotten the 4.0 head, added a header, Clifford intake, and Weber 38 carb.
Without going crazy, what else do I need to do? Flow Kooler water pump? upgrade the stock motorcraft ignition? I'm in coastal SC, so I'm limted to fairly flat roads and trips to the hunt club for a little muddin'. Jeep also has a 5 speed manual tranny and 273 gears in an AMC20 diff, running on 31's with 0 lift (for now!)
I do not want to be stupid, just solid an reliable with this build. Any thoughts and comments are much appreciated.
