Help Identifying these parts on a Gas Tank
FiNorman
Lifetime Supporter
Orlando, FL
1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
I'm down to a bare frame and have a 20 gallon gas tank, and am getting ready to replace the fuel and vent hoses. While taking off the parts to clean the tank I broke off the nozzle on the little white plastic piece, which I believe is a vent or check valve.
Can someone definitively Identify these two white plastic pieces and the 2 rubber hoses that come off them and where do they connect to?
thats a weird looking tank... is it a poly tank?
Perhaps those are the tubes that would go to the check valve / roll over valve from normal steel tank.
Not positive though!
Im pretty sure the rollover valve is Cj specific cause I see request for it alot. Bear with me for a little and I'll try and find a more definitive answer.
Thanks... it is a poly tank... I think it was OE option for a 20 gallon tank. I did see some other forums where they said it was similar to the wrangler, I just wanted to confirm.....
thanks again.
Any thoughts? I might try to roll the dice and see if the wrangler ones work.
  5.0%
