Help Me!! =)
Help Me!! =)
JoeyPsychos
New Jersey
So I took my steering column apart and went to put it back together and not only is the shaft rocking back and fourth it's moving up and down! I will take suggestions about changing upper and lower bearings but they seemed to be fine when I took them out!! Any steering column Gurus out there??:chug:
when you say that you took it apart.......
how apart is "apart"?
Tilt?
and is it rocking back an forth installed?
Post pics if possible
oh and before you go spending too much
sometimes the price of a salvage column is better than the hassle of working on them
Joey, fill out your profile information, it will help us later with anymore questions.
Are you sure it's the bearings? Most of the time the GM tilt steering column (I'm assuming it is tilt because you didn't say) play is from a loose coupling. This is about the most comprehensive article I have found on tightening up the coupling mount. -->> G-Body Loose Tilt Steering Column Repair...Fix it right the first time - El Camino Central Forum : Chevrolet El Camino Forums
X2
and there is a couple of bolts right behind the "tilt spring" that have a nasty habit of coming loose
