Steering Help Tracking Down Death Wobble
JMark
- Solutions
- 1
- Montclair
- '84 CJ-7, 258, Sniper EFI, AX15, Dana 300 HD Outputs Twin Stick 4:1, York OBA, D60, D44 Locked F&R
Looking for some insight on death wobble: 35 Goodyear mtrs, front Dana 44 . YJ OME springs. MORE shackles, Moog Ball Joints, Omix TREs and their HD steering setup.
If I hit a big bump just right at super low speed while turning right such as an intersection she goes into death wobble. Dropping down to 1-2 mph stops it. Also happened at 20-25mph when hitting a pothole on the pass side. Thoughts?
Steering box, pitman arm, Tie rod ends, ball joints, springs and all bushings were swapped about 14 months ago (6500 miles ish) Alignment was set by a shop then and i'm also running a 4 degree caster wedge. Jeep drives great other than this issue.
