Help!!! with a re-wiring problem!!!
electraman
Here's my problem...I just rewired my 78 CJ7 , AMC 304 , 3 speed. I used a NOS still sealed under dash harness. The reason that I replaced it was because the fuse block was broken in half. I used an NOS so it would be plug and play.
This is what is going on... everything works, but when I start it, nothing, the only that happens id the volt meter goes to zero. I have checked the battery and it test good. I have put a new ignition switch on too ( one over the column). I put a new solenoid on as well...Nothing... I have put a jumper on each side of the solenoid I the motor turns over. I have ran a ground wire to the solenoid as well...
Any suggestions?
Any suggestions?
