Help
steve801
Ya know how some of the bolts that go into the frame have nuts welded on the inside of the frame? Well as luck would have it one of those nuts inside the frame rail broke loose. I was thinking of putting a helicoil in there, but the frame is only an eighth inch thick. I was also thinking of cutting a small access on the side of the frame to put a nut in there but was worried about messing with the integrity of the frame. This set of three nut holes holds the front spring shackle and the steering gear mounting bracket in the left front frame rail. Any suggestions on how to tackle this?
