Here is the cam I bought
DIG
Check out the cam kit I bought, will this sound pretty good? Should I buy cam bearings>??
Umm... Link??
Do you have someone who can change out the cam bearings for you? Is the block still in the Jeep?
What are the specs and intended use for your Jeep?
Tire size?
Gear ratio?
What transmission?
Do you plan on daily driving (economy minded use), rock crawling, high RPM use, or towing?
What are your engine specs, bored out? Carb/FI? Intake manifold type? Ex manifolds or Headers- if headers are they shorty or long tube?
IMO that's a lot of cam for a DD Jeep, it is likely economy will suffer. The RPM range is pretty high as well. It would be a fun cam for say a 360 AMX.
