High CB SWR mystery
WACJ5
- Benton City, WA
- 1956 CJ5; 231 Buick, T98/T18, Warn overdrive, 33s, Dana 25/44, 5.38 with lockers, 2.5" Softride lift, reversed front shackles, flipped tie rods, line lock
I put a Cobra CB in my 1956 CJ5 . Did everything according to Firestik and Rightchannelradios installation and troubleshooting guidelines. When tuning the antenna, all channels are way above 3 on the SWR meter.
Checked all system continuity values, continuous when should be, no continuity when that is proper. Changed CBs in case there was a problem with the radio, same high SWR values across all channels. Changed the antenna even though the first one met all checks. Same results.
I would certainly appreciate insight as to what is going on and how to correct the system. The radio is completely useless the way it is.
Thanks.
Thanks.
