Hole in dash above steering column??
brendangsxr
central pa
1975 cj5
3spd
304 v8
Hi everyone, I'm bearing down towards the end of my restoration on my 75 CJ5 . I am currently putting the dashboard back to stock, there is a hole above the steering column and I am not quite sure what goes there! I figured it is either for the wiring for the tach or in the manual it shows a break fault indicator light. I was thinking that. Oils possible go there!! Also does anybody know where I can get hazard flasher indicator lamp? Any help is greatly appreciated. Thanks
Not sure exactly how the setup is on at '75. I have an '81 CJ7 . How large is the hole you are referring to? On my '81 there is a round hole about 1" in diameter right above the steering column. The master cylinder connects through this hole. Are you referring to this or something similar?
Interior Dash Pad
$20.00
  10.0%
