holley 350 cfm on a f head?
Thorwon
Commerce Ga.
1966 CJ5 134"F" 3sp with Warn OD
Anybody ever put a holley 350 cfm on a f head? The Carter I have on it is junk. It floods like crazy at low rpm. I've lowered the float to the point I'm not sure it would run down the road. Even then it won't idle, it just floods. Black smoke out the tail pipe and fouled plugs. Anyway I have a good holley 350 cfm and just wondered if anyone has ever tried to rejet one to match the 134? If so what jets did you use? I know I'll have to build an adapter but that's not a problem.
  5.0%
