how do i fix this
jolley rancher 4
So i got to taking a closer look at mywheels and wheel wells and i noticed my rear wheels are not evenly spaced front to back (my drivers side is about 3.5" back from the front of the wheel well while the passenger is only about 1.75" from the front) the jeep drives really straight and does not pull to either side. the tires are 33x12.5 on 15s and all wear the same (from the center in they are worn more than from the center out) but all 4 look the same no one tire is worse than the others. so i guess my question is how would i make it even without throwing the alignment way out of wack? also im on a really tight budget right now so if it involves anything expensive then i will just be leaving it as is right now since it does run straight.:driving:
