How to adjust for dieseling / engine run on?
PatrickRyan
1978 CJ5 with AMC 304
Motorcraft 2100 carb
MSD 6AL analog ignition
Setup ran fairly well. But starter has been iffy for a while.
Then, 2 weeks ago, Jeep refused to start. No cranking, etc. Just dead key.
I was able to jump across the solenoid on the fender. The starter was fine. The solenoid was the culprit. Didn't have time to mess with it. Real life stuff.
So this past Saturday, I finally had the time to fix it. (I know, all of five minutes lol)
Anyway, I replaced the solenoid with a $28 part from NAPA.
The engine just cranks right up. It runs smoother than ever. It's great. Except, now, the only way to kill the engine after it warms up is to pop the clutch.
If I turn the key off, it never even sputters. Just keeps churning along like I never did anything. I'm sure that I could probably drive the thing if the steering wheel didn't lock up.
This is a completely new behavior. I'm not sure what I did that would have caused this. All I did was disconnect the battery, replace the solenoid and re-connect the wires. No adjustment on the ignition or carburetor.
Any ideas?
Any ideas?
