How to install shocks on a 1978 cj7
Helrazr
Ia
I was wondering what options are there to install shocks on my 1978 CJ7 ?
Shocks are fairly straight forward on a CJ. A little more information on what you are wondering about would be helpful.
The way I see it, shocks are pretty sensitive on a short wheelbase and lightweight CJ. So, I would recommend the good ones and quality gets expensive. The best are Bilstiens and Rancho adjustables are good too, there are also a few others. Lifted CJs require buying by extended length and contraction. Tire air pressure is a big factor here also. If you are not sure you should research this stuff.
Get the softest ones you can find.
Pretty straight forward on the R&R.
I just replaced old ones w cheap monroes from O'Reillys. $100 for all 4. Definitely helped a lot, I wanted soft too.
