How to tell what gear ratio is in your CJ.
- Central FL
CJ submitted a new resource:
How to tell what gear ratio is in your CJ. - How to tell what gear ratio is.
Read more about this resource...
There are several ways to determine your gear ratio.
1) Some diff's still have the OEM tag attached to a cover bolt. This usually gives the information you need including if the diff has Limited slip. The draw back to this...
- Look for a tag on the differential.
- Pull the differential cover and look for the # of teeth stamped on the ring and pinion.
- Count the number of teeth on the ring and pinion.
- Lift the wheels off of the ground and count the drive shaft rotations.
