Hydraulic Clutch Installation, CJ7
Captainlance
I'm installing a hydraulic clutch mechanism in my wife's 1984 CJ7 that I'm restoring. YES, I have searched and read as many postings as I can find, but I still have a problem that I don't see a clear answer to, maybe someone here can enlighten me. The Jeep has a AMC 258 i6 / 4.2l and Tremec/Spicer T-176 . I used a Centric slave and master cylinder for the clutch, the slave bolted right up to the bell housing with existing holes. The assembly has been bled, and I exchanged the clutch pedal from a YJ onto the CJ pedal assembly, so I would have the pin for the push rod.
PROBLEM: slave cylinder travel is only 5/8 of and inch, yes the clutch disengages, but the pedal is VERY low in engagement, barely 2-3 inches off the floor..
SUGGESTIONS?
Any ideas?
Thanks!
Lance
SUGGESTIONS?
Any ideas?
Thanks!
Lance
