Hydraulic clutch troubles! please help.
Tha frame is in the way??? Do you mean the body tub or exhaust? The frame should be nowhere near where the slave cylinder mounts on the lower end of the bell housing.I just took the slave cylinder off my jeep (85 CJ7 ) and when i went to put it back on, it does not fit. there isnt enough room between the bracket and the frame. the only thing i can think of is that the engine shifted somehow...or is there a trick to it??? *boggled*
The driver's side motor mount is usually the one to go, because it's the one that the torque is pulling on instead of compressing when you drive. I still don't understand how the frame could be in the way. A picture would help a lot.ok guys heres on update. i jacked up the tranny a little, put the slave cylinder back on, skid plate is back on but now (lol) the frame is in the way of the hole the line goes into the slave cylinder. still seems the motor is too low! i checked motor mounts, passenger side seems to be fine but theres no rubber on the driver side, but the engine sits evenly. however, the driver side of course is the side with the slave cylinder and that extra inch or so that a rubber thing would give me would be plenty of room. but it would make the engine sit crooked i think. help again! sorry, im a novice!! Thanks so much for the help.
I hope this doesn't sound insulting, but you have to bolt the motor mount in. You can't just replace the rubber part. It's all one piece where the metal is bonded to the rubber. Or did I misunderstnd what you were saying?aww heck man, with mechanic nothing is a silly question. well the skid plate underneath is a homemade job so theres only one set of holes n stuff on it. but thank you! the rubber on the driver side mount is toast. start there n see where it gets me. will i be able to lift up the motor high enough without unbolting anything??
