Hydroboost brake system
NVRDUN
Burleson, Texas
83 CJ-7, 258 In-line six, T-18, Dana 20 Transfer Case w/Terra Low
I am thinking about installing a Hydroboost brake system on my 83 CJ7 . Is there anybody here who has done this in the past? Maybe can tell me the pros and cons of such a change and if you have done it how did you do it. Maybe even a parts list.
I am running 35 x 13.5 x 15 BFG Crawlers and on some of the more extreme trails the stock brakes just don't have enough power to do the job right. I am currently running all stock power brake parts now.
Thanks....James
Thanks....James
:)James,
That is such a large subject that I don't think there is enough room here to properly address it:
You have not mentioned a very important thing? What type of brakes do you have? Disc's or Drums or a combination?
Vacuum Boosters when working properly with disc brakes will generate about 1200 PSI of braking force...........Hydroboost about double that. Lots of guys have gone to the Hydroboost as tire sizes have gotten much bigger than 35's......they are also using the hydroboost systems to steer with by using braking force to apply pressure to a combination of wheel locations..........
Before you spend a lot of money............check out your complete current brake system: Should have at least 17-20 inches of vacuum coming off the manifold........a dual Booster works better than a single.......Disc's work better than Drums...........check your brake pedal ratio and different types of linings can also improve your stoping performance.
:D:D:D:D
Thanks for the input.
I have disk brakes on all four wheels. I changed the back over when we built the Ford 9 inch for the rear. Everything else is stock right down to the pads. I have not checked the vac pressures yet.
:)Was that a conversion or did it always have Power from the factory?
Like I said there are way to many things that need to be addressed regarding an in adaquate stopping brake system...........throwing new parts at it is surely an option............but taking a hard look at your current system is what I would do first.
  • Vacuum
  • Booster size
  • Leaks
  • Master cylinder
  • Correct sizing of Pistons / Calipers IE: if you have added static weight or more inertia related rotational weight via a larger rim & tire your old stock system designed for 29" tires may just not be able to cut it!
  • Vented rotors
  • More agressive Brake lining options
:D:D:D:D
It came from the factory with power brakes.
:)OK one can assume then that you have the correct ratio at the pedal , but check it out.........Then Check out the article "Old Dog" just posted.............
These are all the things I am preaching about like, having the correct pedal ratios, components , rotors & linings Etc.
Spend some time going through that artice and see if you can improve upon your system.
:D:D:D:D
Thanks guys, I will do some more research and testing.
James
