I finally got MY CJ & RUNNING!
Al Lindner
I finaly got the CJ running Idles good but a little High about 200rpm over the 800 the book says Here is the rub it stammers and studders when driving just runs crappy I put a timing light on it and the mark doesnt show.When I reinstalled the distributer I was Very cautious to be @ tdc on#1. I was lined up on the timing marks on the timing chain cover but like I said the mark doesnt show when I try and time it. I pulled a plug and it was sooty as hell. So here are the questions I have
1.Would the AMC 258 i6 / 4.2l run IF I was 180degrees out with the distributer?
2. IS it possible to put the Balancer on backwards (flipped over) ? its Keyed to the crank so My assumption is it will only go on one way
3.Could it be a bad coil (Insufficient Spark)
Please, any info would be greatly appriciated
