i need power steering !!!!!
tyler m
palmdale,california
i have a 1969 cj-5 i think, with a f 134 hurricane four cylinder motor,im not sure wat kinda of tran and transfer case all i know is that i have 4 stick levers
i have a 1969 CJ5 .. i think.
wats the easiest and cheapest way for me to covert to power steering .. wat parts do i need and wat other jeep could i get them from.. please help !! thankyou
I don't know what parts you need, but just wanted to let you know somebody heard you. :) :) :)
I have a 84 CJ7 and power steering is my next upgrade. I got a pump and brackets off a 70 something model at pull apart. There is lots of information using Google about what you need for a CJ7 , not sure about a 5.
Try Google/images "CJ5 power steering"
What style steering box do you have on there now (a pic will help me). I have a number of power steering boxes available (Saginaw style), but I'm not sure if they will bolt up to your frame or not. Are you able to do some fabricating? If so, that will probably help.
As soon as I get a chance I will get pics. Thanks
I'm not sure what year the change was made but you may have the Ross steering box in your CJ and is not easily convertable to P.S.
If so you will be in for some fabrication and welding work. I don't think I have ever seen a P.S. pump mounted on a 134, not that it can't be done but at 76hp freash and new there is no surplus of power to drive other things and still be able to get down the road.
I think it's cool when you leave the old Jeeps the way they came but it's your call.:)
