I think engine is toast?
Jeff Kavanagh
- Owen Sound, Ont., Canada
- 85' CJ7, straight 6, D300, All I know so far about he transmission is that it is a 5 speed manual. Still trying to learn what everything else is. lol
It's the AMC 258 i6 / 4.2l straight 6.
This jeep is out of an old damp equipment shed where it sat for around 5 or so years. When I first got it home it would not crank over by hand.
I pulled the plugs and put a Crown penetrating oil into it.
Slowly I worked a pry bar on the fly wheel back and forth and the engine came free. Free enough that a simple turn on the fan belt would turn it.
Did some other work with the ignition system (new solenoid, starter, etc., got it turning over with the plugs still out.
Next put new plugs in it and turned it over by putting gas in the carb.
Today I started it and it ran for around 5 seconds and then ceased right up. It won't even turn over with the pry bar. The oil level and all was good too before I did all of this.
I'm guessing the engine is done?
Jeff
Jeff
