Idle speed / need help
Pdx1jmh
- Eagle point Oregon
- 1978 cj7 304 DUI and Howell fuel injection t18 and Dana 300 t case Ford 9 in front and amc20 in rear. 4.88 ratio and 35 ss boggers
1983 cj7 158 4 cyl 4 speed Dana 300 amc20 rear Dana 35 front standard fuel and electronics
I have a 1978 CJ7 with AMC 304 and Howell fuel injection and DUI distributor and ignition. I have also installed a painless wire kit for the Jeep.
I have hooked up everything correctly and have made several calls to painless Howell and DUI. I have changed all sensors idle o2 throttle temp map as well as the computer and the DUI
I have no vacuum leaks I have checked with carb cleaner.
The problem I have is an idle speed of 3000rpm.
I am at a loss and do not know what to do at this time.
Any help would be appreciated
