Electrical Ignition Control Module Melting
Oldguyinajeep
Derby, KS
'86 CJ-7 258ci 4spd Dana 30 and 44
Howell TBI Fuel inj, Headers, Dual batteries, Warn winch/air compressor, rear
disc brake conversion, Detroit locker (rear), Eaton E-locker (front), 4:10 gears, 2.5 in Rancho lift, 1" body lift, fully armored, 35" BFG KM2s, Warn front hub conversions, line locks front and rear, roll cage, warn front bumper, rock hard rear bumper/tire carrier, DUI ignition, dual electric fans, LED rock lights
I noticed some black semi-hard goo on the floor under my jeep. It had come from my ignition control module. When I removed it, enough of the goo had melted out that the circuit board was visible. The jeep would still start and run, but it obviously needed replacing, which I did. I got the part (Standard Ignition) from OReilly Auto. After driving it only a couple of brief trips, I've noticed the same thing is happening again.
I had read somewhere that if you leave the ignition switch in the accessory position for a long time, it can cause this problem. I've made very sure that the lock cylinder switch is in off and locked position, so I don't think this is the issue. I am suspicious that this may be related to the fact that I rebuilt my steering column (including new lock cylinder and ignition switch located on the lower part of the column). Is it possible that I don't have the switch adjusted properly, or that the switch is faulty? It seems to function well.
Also, please note that I have a Davis DUI ignition and a Howell Fuel injection on this jeep.
Any help is appreciated
Bypass the ignition switch completely, run the Jeep and see. You need to eliminate the old ignition system, drive for a while and work back.
