I'm a idiot
playnsnookie
I decided to refresh the suspension on my 83 Scrambler . I ordered a new RE 4.5 lift , along with new drag link/tie bar assembly and steering stabilizer. So like a giddy teenage girl , I couldn't wait till the parts came in. In my infinite wisdom , I decided to tear down the front end to prepare for the new gear. ( Instead of doing a side at a time....) I jacked up the rig, stabilized it, and proceeded to disassemble the front end. I removed the front tires and shocks. I then placed jack stands under the axel and removed the springs / shackles. To keep the axel from rotating on the jack stands, I decided to use a floor jack to support the back of the front differential ( I did not remove the shaft from the front diff) . I came out this morning to a 6 inch diameter pool of gear lube . The dang floor jack did not hold its end of the deal. ( Should've used a another jack stand) Anyhow, The axel rotated backwards on the stand , causing a bad angle on the shaft. Here are my questions.
1. Did I mess up the rear seal in the front differential due to the angle of the drive shaft?
2. How do I determine the exact position of the axel ( from a rotation standpoint) when installing the new springs? What should be the proper Castor? + or -
Thanks in advance.....
