I'm having a real hard time adjusting my clutch
ShowroomShine
Putting my jeep back together and having trouble adjusting the clutch. I have the rod and adjustment nut seemingly near all the way out, and the clutch wont disengage. I push the pedal down, and try to shift into reverse and it still grinds into gear.
I am certain I put the clutch and pressure plate together correctly, what else could be the problem?
No burs on shaft or splines.
New pressure plate
New throwout bearing
Fork is in good shape
Turned flywheel
New pressure plate
Turned flywheel
