    To dismiss this notice
    click the top right X.
injector problems
injector problems
SemperFiCJ5
Jacksonville North Carolina
1974 CJ5.
  • Right fuel injector isn't spraying.
I'm not sure why that is happening.
If you do need to replace the injector, you should be able to find one easily online, for example at partstrain.com.
Sometimes there might be something clogging the nozzle from the inside.
For example dirt, or bits of fuel cell insulation, or even metal.
If you think that could be the problem you have to clean, or replace, the injectors.
$100.00
  50.0%
