Installing Hydraulic Master Cylinder
jaxjeeper
- Jacksonville Beach, FL
- 1984 CJ7 258 I6
T4 Tranny (I think)
Dana 300
I am doing a repower of my 1984 Jeep CJ7 . Part of the process will be converting from the old mechanical clutch to a hydraulic clutch.
How do I mount the master cylinder? Is there a thread or blog that shows pictures? I am guessing the pushrod goes through the firewall and connects to the clutch pedal. When the clutch is pressed, the pushrod causes the fluid to compress which signals the slave to disengage the clutch plate. I'm just not sure how the pushrod is connected to the clutch pedal.
Do you completely remove all the old mechanical clutch linkages?
