Steering Is something missing?
Vikingone
Lake Worth FL
85' CJ7, 4.2 Liter, swapped in T18
I’m almost completed putting power steering into my 84 Cj. Everything from my donor 6cyl matched right up to the 4 cyl. Except the pressure hose. No biggie, ordered it and installed. Only problem I’m seeing is with the pump. I used all the original parts but the belt is slightly off. 518e8ea48ac9eeacd7eb7eb8b6aaaec5.jpg9469e4685befc9e721a40c68b0b2cc3b.jpg
I’m wondering if I’m missing some sort of spacer. Thinking of just shimming it with washer.
The only thing I can think of is the water pump pully having a different depth. Here's mine ignore the damagecab721165c8f41687b3d439f2e7195fd.jpg6f34dd91073b7852e5c5cf7036f05992.jpg
Sent from my E6810 using Tapatalk
Maybe try some type of spacers behind the bracket ? Could be the pulley is different, took mine off a few months ago and just can't remember. I know I saved it just in case. With old jeeps you just never know
Here's a factory 4 banger power steering. It's off as welld16bfba65ba3370279a12bf9d88ce28b.jpg
Mine was aligned correctly :poke:
Just a few months ago I removed my 4 banger out of my CJ. Was working like a champ with 238,000 miles, but it and I are no longer young and have many miles, and I didn't want to do this in my 70s. The AMC 258 i6 / 4.2l I bought and rebuilt, the PS pump lined up great but the alternator needed some spacers. Was a pretty easy fix
My AMC 258 i6 / 4.2l is posted above with the busted fan is aligned perfectly
looking at the pictures i see that it might be the power steering pump pulley look at the pictures you see that the pump pulley sets out further than the one you have.
